2013 Kenworth T800 Tri-Drive – Heavy-Duty Fold-Up Crane Truck
Posted Date: Aug 1st, 2025 at 04:24 AM
Extreme Power | High-Capacity | Built for Demanding Jobs
🔧 Truck Specifications:
  • Make/Model: Kenworth T800 Tri-Drive
  • Year: 2013
  • Engine: Cummins ISX or PACCAR MX (confirm exact engine)
  • Transmission: Eaton Fuller manual (confirm speed)
  • Drive: Tri-drive (6x8 heavy-duty) for maximum traction and load capacity
  • Cab: Day cab with premium interior, air-ride seat, A/C, and heat
  • GVWR: Extremely high-capacity configuration for crane applications
🔧 Crane Specifications:
  • Type: Hydraulic fold-up (knuckle boom) crane
  • Lifting Capacity: [Insert if known, typically 20–40 ton range]
  • Boom Reach: [Insert reach if known]
  • Controls: Hydraulic controls and/or remote operation
  • Condition: Fully functional, well-maintained, and job-ready
  • Tri-drive chassis for heavy loads and exceptional stability
  • Fold-up crane for compact transport and quick setup
  • Heavy-duty suspension and drivetrain for extreme-duty operations
  • Ideal for oilfield, industrial, and construction lifting
  • Well-maintained unit – ready to go straight to work
  • Oilfield and rigging operations
  • Heavy construction and infrastructure projects
  • Industrial equipment installation and material handling
  • Utility and municipal heavy-lift applications
