ALLU PM200 ROTARY DRUM SOILS-SLUDGE-COMPOST MIXING 200-350 CLAS
Posted Date: Oct 18th, 2023 at 05:59 PM
Price: $30000.00
The Allu PM200 is a hydraulic equipment attachment designed for excavators in the 20-30 ton range. It is used for various tasks such as mixing compost, sludge, or flammable materials, as well as mixing cement slurry with sand or gravel to create a hard cement surface.
The unit is in good condition and can be mounted on excavators with 90 mm or 80 mm pins, depending on the excavator class. It has an operating weight of 4,200 lbs and requires a flow rate of 100 liters per minute at 2500 PSI, providing 80 kW or 108 HP of power.
The Allu PM200 is designed for durability and easy mounting on excavators. It is capable of efficiently handling hard materials like clay, peat, silt, sludge, or polluted soil. The mixing efficiency is optimized through the horizontal position of the rollers and the unique design of the mixing elements.
The unit can process materials up to a depth of 3 meters, depending on the excavator's equipment and the condition of the material. It can be used for time-consuming tasks and is a versatile tool for both small and large-scale projects.
The Allu PM200 has a solid steel welded construction and wear-resistant steel parts that can be replaced. It is powered by the hydraulic system of the excavator and requires minimal maintenance. Mounting the attachment onto the excavator can be done easily using fingers or a quick-mounting adapter.
Make: Allu
 Model: PM200
BasicMachine Size - 20-30 tons
 Serial Number: 04PM200023
* Transport Dimensions: 101" L x 56" W x 61" H
* Operating Weight: 4,200 lbs
 * 80 KW = 108 HP AT 100 LITRES PER MINUTE FLOW AT 2500 PSI
Features of Unit:
Designed For Durability Easy Mounting Mixing Of Different Materials Specifications Pin Diameter: 90 mm
Distance to Pins (OC): 19" to Ears (ID): 16"
Fits: Set up for any 250-350 Class Excavator
Maximum working depth: 78"
Hydraulic: Two-way Rotation
The ALLU PM Power Mix is a hydraulic equipment attachment designed for excavators. When attached to an excavator, it transforms into a mobile and efficient mixing plant.
The ALLU Power Mix is specifically designed to handle very hard materials, including clay, peat, silt, sludge, and polluted soil, with great efficiency.
Its mixing efficiency is achieved through the optimal horizontal position of the rollers and the unique design of the mixing elements. The rollers move and mix the material in three directions simultaneously.
With the ALLU Power Mix, material processing can be done to a depth of up to 3 meters, depending on the excavator's equipment and the condition of the material.
Since the ALLU Power Mix is an additional attachment, the excavator can still be used for other operational tasks while benefiting from the mixing capabilities.
Whether it's a large-scale project or a small amount of work, the ALLU Power Mix is a versatile tool suitable for various tasks.
The ALLU Power Mix features a solid steel welded construction and all wear parts are made of wear-resistant steel, ensuring durability. The wear parts can also be easily replaced when necessary.
The rotation of the Power Mix is powered by the excavator's hydraulic system through a radial piston motor and a chain drive. This design minimizes the need for maintenance.
Mounting the ALLU Power Mix onto an excavator is easy and can be done using fingers or a quick-mounting adapter.
Additionally, the ALLU Power Mix can be used with the ALLU Power Mix Feed System. This system includes the ALLU PF Pressure Feeder, which injects the binding agent beneath the ground directly to the middle of the mixing drums on the Power Mix. This guarantees better mixing with the base material. The PF is a remote-controlled unit that follows behind the lead excavator. The Power Mix is available in three different model sizes, allowing for depths of 5, 10, and 15 feet (1.5, 3, and 4.6 meters).
For more information about the ALLU PM Power Mix and the ALLU Power Mix Feed System, you can contact 800/939-2558 or visit www.allu.net.
