EMGLO WHEELBARROW 3 HP 2 STAGE 200 PSI DEWALT PUMP PORTABLE COMPRESSOR
Price: $750.00
FOR SALE: EMGLO WHEELBARROW AIR COMPRESSOR – COMMERCIAL GRADE – LOW HOURS
🔥 Built for Demolition Sites – Fully Upgraded & Ready to Work
Make/Model: EMGLO with New DEWALT 2-Stage 200 PSI Pump (Pump alone retails for $1,100 USD / $1,500+ CAD)
Motor: 3 HP, 220V Single Phase, Induction Motor (Newer unit)
Airflow: 15 CFM @ 90 PSI / 11.5 CFM @ 200 PSI
Max Pressure: 200 PSI
Tank Capacity: 7.8 Gallon Wheelbarrow Style
Pump Type: Cast Iron, Oil-Lubricated, 2-Stage Piston Pump
Duty Cycle: Full Continuous Duty – Built for Jobsite Toughness
Voltage/Current: 240V AC / 13.5 Amps – Plug-and-play with cord and plug included
Dimensions: 42.5” L x 18.25” W x 24.75” H
Weight: Approx. 150 lbs
Noise Level: 85 dBA
Outlet Size & Type: 3/8” and 1/2” NPT, Female
💪 Built Tough – Not Chinese Junk
Purpose-Built: Designed specifically to meet the high-pressure needs of demolition and on-site trades
Powerful Output: Runs 5 framing guns, large air impacts, and high-demand tools
Painting-Ready: Can handle two paint guns simultaneously with steady airflow
Low Hours: Lightly used – over $3,000 CAD invested in build and upgrades
🔧 Additional Info:
Pump Life Expectancy: 5,000+ hours
Control Type: On/Off with Pilot Valve
Certified: CSA & UL Standards
🏁 Ready to Plug In & Test
Bring your hose and tools – Unit is fully functional on-site
📍 Located in BC – Owner Retiring and Leaving Province
📞 Frank: 604-476-7777
