GX75 Hydraulic Breaker by Gorilla Hammers – Power Meets Efficiency!
Posted Date: Mar 11th, 2025 at 07:07 PM
💥 Conquer the Toughest Jobs with the GX75 Hydraulic Breaker from Gorilla Hammers! 💥
The GX75 Hydraulic Breaker is designed for heavy-duty demolition, excavation, and concrete breaking, delivering exceptional power and efficiency for demanding job sites. Whether you're tackling commercial projects or urban construction, this breaker provides the impact force and durability you need to get the job done right.
🔥 Key Features & Specifications:
✔️ Impact Energy: 1,000 ft-lb – High-powered for maximum efficiency.
✔️ Blows Per Minute: 460-950 – Adjustable for different applications.
✔️ Operating Weight: 1,160 lbs – Heavy-duty yet well-balanced.
✔️ Tool Diameter: 3.15 inches – Engineered for durability.
✔️ Carrier Weight Compatibility: 9,900 - 19,800 lbs – Works with a range of excavators.
✔️ Oil Flow Rate: 12-21 GPM – Ensures smooth hydraulic performance.
✔️ Operating Oil Pressure: 1,400 - 1,850 PSI – Provides consistent impact power.
✔️ Noise Level: Low-noise technology – Perfect for urban and residential areas.
🔹 Why Choose the GX75 Hydraulic Breaker from Gorilla Hammers?
✅ Heavy-Duty Performance – Easily breaks through tough materials like concrete and rock.
✅ Built for Durability – Constructed with high-quality materials for longevity.
✅ Versatile Applications – Ideal for demolition, excavation, and roadwork.
✅ Efficient & Quiet – Engineered for minimal noise and maximum power.
📌 Upgrade your equipment today! Get the GX75 Hydraulic Breaker from Gorilla Hammers now at www.gorillahammers.com 🚧💥
