OKADA ORV7500 โ€” Mid-Class Hydraulic Breaker 30 -45 TON ECAVATOR ONCRETE - ROCK HAMMER
Price: $45000.00
๐Ÿš€ Factory Shop Rebuilt with 6-Month Okada Factory Warranty ๐Ÿš€
๐Ÿ“ Location: Langley, BC (Ships directly from our yard)
๐Ÿ’ฐ Price:ย $45,000.00 CAD (New unit costs $105,000.00 from Okada)
Key Features & Details:
  • 2020 Model, purchased in 2020, but now considered a 2023 unit after a full Stage 2 rebuild.
  • Complete rebuild performed at Okadaโ€™s Oregon factory ($27,000.00 USD / $37,000.00 CAD).
  • Rebuild Includes:
    • All new bushings.
    • New seal kit.
    • New pistons.
    • 1 brand new & 1 slightly used original Okada Moil Point (2 total).
    • Resealed at Okada Factory Repair Shop (only used lightly before COVID; resealed due to sitting idle).
    • New nitrogen charge for optimal performance.
๐Ÿ› ๏ธ Ready to Work - Okada ORV7500 Hydraulic Demo Hammer Breaker Chisel Attachment Tool
๐Ÿ”น Low-hour 7500 ft-lb hammer, used for onlyย one job before COVID.
๐Ÿ”นย Invoice Available (See image #3).
๐Ÿ”นย Factory-tested & certified rebuild with warranty.
๐Ÿ”น Shipped on our account for fast service & great rates.
๐Ÿ’ฒ Price:ย $45,000.00 CAD
Why Choose the Okada ORV7500?
๐Ÿ”นย Auto-Lube System: Easily adaptable to most automatic lubrication setups.
๐Ÿ”น Main Valve: Internal control valve systemย increases impact energy while keeping temperatures lower.
๐Ÿ”นย Large Capacity Accumulator: Reduces shock load in the system.
๐Ÿ”น Stroke Adjuster: Variable speed controlย maximizes productivity.
๐Ÿ”นย Original Holding System: Secure powercell placement reduces recoil.
๐Ÿ”น Larger N2 Gas Chamber: Ensuresย high-impact power.
๐Ÿ”น Long Stroke Piston: Boosts impact power while reducing vibration & recoil.
๐Ÿ”น Dual Chisel Retaining Pin: Heavy-duty pins extendย service life.
๐Ÿ”น Durable Breaker Bracket: Heavy-duty bottom plate for noise & vibration reduction.
Technical Specifications:
  • Impact Energy Class: 7500 ft-lb / 10,170 Joules
  • Operating Weight: 5,950 lbs / 2,698 kg
  • Oil Flow: 63-72 gpm / 238-272 lpm
  • Frequency:
    • L-Mode: 230-400 bpm
    • S-Mode: 270-470 bpm
  • Operating Pressure: 2,320-2,600 psi / 157-180 bar
  • Mechanical Energy: 98-133 HP / 73.4-99.5 kW
  • Mechanical Energy (Avg): 115.5 HP / 86 kW
  • Unit Working Length: 124 in / 315 cm
  • Tool Diameter: 6.1 in / 155 mm
  • Tool Working Length: 30.2 in / 767 mm
  • Noise Level: 85 dB(A) at 119-167 ft / 36-51 m
  • Carrier Weight Range: 60-92 lbs / 27-42 M ton
๐Ÿ“ข Bonus Deal:
We also have a $80K New Old Stock Okada Demolition Processor for 200-350 class machines โ€” Available for $25,000.00! (Check our other ads)
๐Ÿ“ž Contact:
Frank - 604-476-7777
