Werk-Brau 24 - 36 INCH EXTREME DUTY 200-240 CLASS
Posted Date: Oct 21st, 2023 at 09:47 AM
Price: $5000.00
Extreme Duty American-Made T-1 Steel Buckets for Excavator, C/W 12.25 Inches Between Ears and 80mm Pins; Fits Any 200-240 Excavator; COMPOSES OF THE FOLLOWING:
1) 12.25 INCHES BETWEEN EAR - $5000.00; 1) 24-INCH PIN OR PIN GRABBER 3 TOOTH BUCKET C/W 80MM PINS
2) 12.25 INCHES BETWEEN EAR - $6000.00 36-INCH PIN OR PIN GRABBER 5 TOOTH BUCKET C/W 80MM PINS.
EACH OF THESE BUCKETS IS WORTH $8000.00–10,000.00 USD.
ORDER THE SET OF 2 BUCKETS FOR $10,000.00 CDN OR BUY THE 2 BUCKETS FOR $5000.00 - $6,000.00 EACH
Every bucket has been hard-surfaced, assembled with pins, and is in perfect condition, ready for use.
Exceptionally well-made T-1 American-built steel buckets from our low hour (5000 hour) THAT THE BUYER REQUIRED A WEDGE TO COMPATIBLE WITH HIS OTHER MACHINES, LINKBELT 235 X3?
ALL 160-240 CLASS EXCAVATORS WILL FIT THIS
ALL ARE LOCATED IN LANGLEY, BC IN OUR YARD.
END OF EXCAVATING YARD CLEANING -DEMOLITION ATTACHMENTS - FOR MORE INFORMATION, VISIT MY WEBSITE OR OTHER LISTINGS, OR EMAIL ME TO GET A COMPLETE UPDATED LIST OF MORE THAN 100 ITEMS
YOU GET A FULL SET OF BUCKETS RIGHT NOW WITH THIS.
NOT NEED TO AVOID MANY WEEKS FOR DELIVERY OR BUILDING
FRANK: 604-476-7777; 1-(833) 693-9323; TOLL-FREE
Werk-Brau produces all attachments in accordance with OEM specifications for all excavator makes and models.
Applications Suggestioned
Severe-duty buckets from Werk-Brau are made with an aggressive dig angle specifically to dig efficiently under the hardest circumstances. This bucket is best used for high abrasive applications, shot rock, demolition work, and mild prying, among other things. This bucket can also be used for material handling when used in conjunction with a thumb.
Establishment
Every critical or high wear component is made of T-1 steel. This bucket has horizontal wear straps, tapered side plates, and an extra-thick cutting edge supported by a wear plate that covers the entire bottom of the bucket. Side wear plates prolong the bucket's operational life by shielding the sides in high-wear areas. The severe-duty excavator bucket's tip radius meets or exceeds O.E.M. requirements. Every bucket is designed with tapered side plates to facilitate easier dumping and lessen wear on the bucket's sides. The cutter bit is composed of robust cast metal.
Options for Cutting Equipment
fitted with teeth that meet industry standards for added durability. To withstand the harsher digging application, teeth are typically made larger. There is a variety of high-quality brand teeth available for selection. Box rippers can be installed and made available upon request.
customary sizes
There are 3/8 cubic yards to 4 cubic yards available in different widths. On request, custom configurations and capacities are offered.
Extra Elements
For added endurance, bolt-on side cutters are highly recommended. Box rippers can be installed upon request and are available. For more information, get in touch with Werk-Brau directly or ask a dealer for a quote. Special designs and capacities are available.
