2001 National Crane Truck – Strong, Simple & Work-Ready
Posted Date: Jul 9th, 2025 at 05:33 AM
Price: $78000.00
🏗️ 2001 National Crane Truck – Strong, Simple & Work-Ready
Hydraulic Boom Truck | Budget-Friendly | Ideal for General Lifting & Material Delivery
🚛 Truck Platform Overview
(Specs may vary slightly depending on chassis; confirm unit details)
  • Make/Model: National Crane (likely 500C, 600E, 800C, or 8100 series – confirm actual model)
  • Mounting Chassis: Freightliner / International / Sterling / Peterbilt (confirm make/model)
  • Engine: Caterpillar / Cummins diesel (mechanical or early electronic) – known for durability
  • Transmission: Manual or automatic (varies by unit)
  • GVWR: Typically 33,000–60,000 lbs – heavy-duty for crane hauling
  • Mileage: [Insert actual miles] – Fleet-maintained, low-hour unit
  • Cab Features:
    • Day cab with standard gauges and controls
    • Clean interior, PTO switch, and climate control
    • Air ride seat (if equipped), AM/FM stereo
🏗️ National Crane System Details
  • Crane Type: Telescopic boom truck-mounted crane
  • Capacity:
    • Approx. 15,000 – 26,000 lbs max lifting capacity (depends on model)
    • Ideal for general lifting, HVAC placement, roofing, and truss work
  • Boom Reach:
    • Main Boom: 40–80 ft
    • With Jib (if equipped): Up to 100–120 ft total vertical reach
  • Controls:
    • Dual-sided operator control stations or enclosed cab (depending on configuration)
    • Smooth hydraulic operation with fine feathering
  • Rotation: Full 360° hydraulic swing
  • Winch: Heavy-duty winch with load block & cable system
  • Outriggers: Hydraulic A-frame or H-style outriggers – stable on varied terrain
  • Load Charts: On-unit charts and LMI system (if equipped)
🔩 Flatbed & Utility Setup
  • Bed Length: Approx. 20–24 ft steel flatbed
  • Deck: Solid steel with anti-slip coating and tie-down points
  • Toolboxes: Optional underbody toolboxes for rigging storage
  • Rear Access: Forklift-compatible or step-up rear deck
✅ Ideal For:
  • General contractors
  • Roofing & siding installation
  • Truss setting & framing support
  • Light to mid-weight industrial lifting
  • HVAC unit placement
  • Sign installation companies
  • Rental fleets and utility support
🔍 Condition & Extras
  • Year: 2001
  • Mileage: [Insert actual figure]
  • Crane Hours: [Insert or estimate if known]
  • Hydraulics: Smooth operation – no known leaks
  • Tires: 70–85% tread remaining
  • Brakes: Air brakes tested and compliant
  • Title: Clean, no liens or salvage history
  • Location: [Insert city/state] – available for inspection
💰 Financing & Delivery
  • Priced for quick sale – great value for a functioning crane truck
  • Nationwide delivery can be arranged
  • Financing available for qualified buyers (OAC)
  • Package deal options available for fleet buyers
🔧 Why Choose This National Crane?
  • Proven reliability – National Crane is a top name in hydraulic boom trucks
  • Pre-emissions diesel – Simpler maintenance, no DEF or DPF
  • Cost-effective lifting solution – Handles a wide range of jobs without the cost of newer models
  • Great entry point for contractors needing lifting power on a budget
