2018 John Deere 75G Excavator โ€“ Compact Radius. Full-Sized Power.
Posted Date: Jul 12th, 2025 at 08:36 PM
Price: $119900.00
๐Ÿšœ 2018 John Deere 75G Excavator โ€“ Compact Radius. Full-Sized Power.
Tight Tail Swing | Easy Transport | Perfect for Utility & Residential Work
๐Ÿ”ง Machine Overview โ€“ John Deere 75G
  • Make/Model: John Deere 75G
  • Year: 2018
  • Operating Weight: Approx. 17,952 lbs (8,140 kg)
  • Engine: Yanmar 4TNV98C โ€“ Tier 4 Final Emissions Compliant
  • Horsepower: 56.9 HP (42.4 kW)
  • Max Dig Depth: 13 ft 6 in (4.1 m)
  • Max Reach: Approx. 21 ft 9 in (6.63 m)
  • Tail Swing: Reduced radius design โ€“ perfect for working in confined spaces
๐Ÿ› ๏ธ Performance & Hydraulic Features
  • Hydraulic System:
    • Smooth and responsive with load-sensing hydraulics
    • Factory auxiliary hydraulic lines for thumbs, breakers, and augers
    • Quick coupler capable for fast attachment swaps
  • Fuel Efficiency:
    • Auto-idle and economy modes reduce fuel burn without compromising power
    • Extended maintenance intervals = lower operating costs
  • Undercarriage:
    • Durable steel tracks with optional rubber pads
    • Wide stance for enhanced digging stability
๐Ÿ‘จโ€๐Ÿ’ป Operator Station
  • Cab:
    • Enclosed, pressurized, ROPS/FOPS certified cab
    • Full climate control with heat and A/C
    • Low noise and wide visibility glass
  • Controls:
    • Pilot joystick controls with adjustable sensitivity
    • Multi-function LCD monitor with diagnostics, hours, fuel usage, and maintenance alerts
  • Seat: Adjustable, air-suspension operator seat with armrests
โœ… Ideal Applications
  • Urban excavation and tight job sites
  • Landscaping and grading
  • Utility trenching and backfilling
  • Residential and commercial construction
  • Farm and municipal maintenance
๐Ÿ” Condition & Inclusions
  • Condition: Clean, well-maintained, jobsite-ready
  • Undercarriage: [Insert % or note recent track service]
  • Hydraulics: Leak-free and responsive
  • Includes:
    • Heavy-duty trenching bucket
    • Quick coupler (if applicable)
  • Title: Clean and transferable
๐Ÿ’ฐ Pricing & Financing
  • Competitively priced for a premium mid-size compact machine
  • Delivery options available nationwide
  • Trade-ins accepted
๐Ÿ”ง Why Choose the 2018 John Deere 75G?
  • Big machine power in a compact frame โ€“ perfect for restricted jobsites
  • Trusted John Deere reliability and resale value
  • Ready for all-season work with full cab and auxiliary lines
  • Easy to trailer and transport for mobile contractors
  • An ideal fit for any growing fleet or small contractor needing dependable performance
