2023 OKADA OKADA FACTORY SHOP REBUILT 7500 FT LB 250 - 450 CLASS EXCAVATOR HAMMER / CONCRETE - ROCK BREAKER
Price: $45000.00
OKADA ORV7500 — Mid-Class Hydraulic Breaker
✅ Factory Shop Rebuilt — 6-Month Okada Factory Warranty
📍 Location: Langley, BC (Ships directly from our yard)
💵 Price: $45,000.00 CAD
(New replacement cost: $105,000.00 from Okada)
🔹 Key Features & Details:
2020 Model — purchased new in 2020, now considered a 2023 unit after full Stage 2 rebuild.
Factory Rebuild — performed at Okada’s Oregon facility.
Rebuild cost: $27,000.00 USD / $37,000.00 CAD.
Rebuild Includes:
All new bushings.
New seal kit.
New pistons.
1 brand new and 1 slightly used original Okada Moil Point (total of 2 tools).
Complete reseal at Okada Factory Repair Shop.
New nitrogen charge for optimal power and performance.
✅ Ready to Work — Low-hour hammer used for only one project prior to COVID. ✅ Factory Tested & Certified Rebuild — Warranty included. ✅ Invoice Available (See image #3). ✅ Fast Shipping — Shipped on our account with competitive freight rates.
🔹 Why Choose the Okada ORV7500?
Auto-Lube System — Easily adaptable to automatic lubrication systems.
Main Valve — Internal control valve boosts impact energy while reducing heat.
Large Capacity Accumulator — Reduces shock load on your carrier machine.
Stroke Adjuster — Variable speed control for optimized productivity.
Original Holding System — Powercell placement reduces recoil and improves durability.
Larger Nitrogen Gas Chamber — Maintains high-impact force.
Long Stroke Piston — Reduces vibration while increasing striking power.
Dual Chisel Retaining Pins — Extends service life of the tool.
Durable Breaker Bracket — Heavy-duty bottom plate reduces noise and vibration.
🔹 Technical Specifications:
Impact Energy Class: 7500 ft-lb / 10,170 Joules
Operating Weight: 5,950 lbs / 2,698 kg
Oil Flow: 63-72 GPM / 238-272 LPM
Frequency:
L-Mode: 230–400 BPM
S-Mode: 270–470 BPM
Operating Pressure: 2,320–2,600 PSI / 157–180 bar
Mechanical Energy:
98–133 HP / 73.4–99.5 kW
Average: 115.5 HP / 86 kW
Unit Working Length: 124 in / 315 cm
Tool Diameter: 6.1 in / 155 mm
Tool Working Length: 30.2 in / 767 mm
Noise Level: 85 dB(A) at 119–167 ft / 36–51 m
Carrier Weight Range: 60–92 lbs / 27–42 metric tons
🎁 Bonus Deal:
$80K New Old Stock Okada Demolition Processor
(Fits 200–350 Class Machines)🔥 Available for $25,000.00 CAD!
(Check our other ads for full details)
📞 Contact:
Frank — Call/Text/WhatsApp: 604-476-7777
