Hydra-Lift Crane โ€“ Rugged, Simple, and Built for Work
Posted Date: Jul 9th, 2025 at 05:38 AM
Price: $75000.00
๐Ÿ—๏ธ Hydra-Lift Crane โ€“ Rugged, Simple, and Built for Work
Reliable Hydraulic Lifting | Field-Tested Strength | Ideal for Utility, Construction & Material Handling
๐Ÿ—๏ธ Crane Overview โ€“ Hydra Lift Hydraulic Crane
(Note: Hydra-Lift offers several models. Customize specs below based on your specific unit โ€“ 5000 lb, 8000 lb, 10,000 lb, etc.)
  • Make/Model: Hydra-Lift [Insert specific model, e.g., 8000 or 10K series]
  • Lifting Capacity:
    • Approx. 5,000 โ€“ 10,000 lbs (model-dependent)
    • Designed for safe, consistent hydraulic lifts across varied jobsites
  • Boom Type:
    • Telescopic or articulating (confirm configuration)
    • Steel-reinforced hydraulic boom sections
  • Reach:
    • Horizontal: Up to 20โ€“30 ft
    • Vertical: Approx. 25โ€“35 ft lifting height
  • Mount Type:
    • Truck-bed mounted, skid-mount, or standalone โ€“ versatile install options
  • Rotation: 360ยฐ continuous or 180ยฐ mechanical swing (model-specific)
  • Winch System: Heavy-duty cable winch with durable hook block
  • Power Source: PTO hydraulic (truck-mounted) or self-contained hydraulic pump
๐ŸŽฎ Controls & Functionality
  • Operator Controls:
    • Side-mounted levers or optional pendant remote
    • Easy-to-operate with precision feathering for safe placement
  • Safety Features:
    • Load-limiting valves
    • Hydraulic bypass protection
    • Emergency shut-off (if applicable)
  • Stability:
    • Manual or hydraulic outriggers for ground support
    • Locking pins and stabilizer pads for balanced lifting
๐Ÿšš Compatible with These Platforms
  • Service trucks (Ford F550โ€“F750, Freightliner M2, International 4300/7400)
  • Flatbeds, mechanic bodies, utility trucks
  • Agricultural trailers, tow trucks, and construction platforms
โœ… Applications
  • Equipment loading/unloading
  • Generator or tank placement
  • Roofing and construction supply delivery
  • Utility pole handling
  • Agricultural and oilfield equipment lifts
  • Tree service or landscaping material delivery
  • Welding, fabrication, or mobile mechanic operations
๐Ÿ” Condition & Details (for Used Units)
  • Year: [Insert manufacture year]
  • Condition: Fully operational โ€“ tested and serviced
  • Mounting Base: Clean welds, reinforced subframe
  • Hydraulics: Leak-free cylinders, pressure-tested lines
  • Title/Docs: Clean title or serial number tag intact
๐Ÿ’ฐ Pricing & Delivery
  • Great value compared to new cranes from Venturo, IMT, Stellar, or Auto Crane
  • Financing and install options available (OAC)
  • Mounting & PTO setup services offered
  • Nationwide delivery or crating for shipping
๐Ÿ”ง Why Choose Hydra Lift?
  • Trusted for decades in oilfields, utilities, and agricultural sectors
  • Mechanically simple + hydraulically powerful = low maintenance cost
  • Easily mounted, controlled, and serviced
  • Excellent for contractors, small fleets, and field teams needing reliable lifting without high cost
