Simex TF 1100 Cutter Head β For 200β350 Class Excavators β Low Hour Demo Model β 35" Excavator Rotary Cutter Head For 36 Inch Trenching
Price: $75000.00
π§ Simex TF 1100 Cutter Head β For 200β350 Class Excavators
β Low Hour Demo Model β 35" Excavator Rotary Cutter Head For 36 Inch TrenchingΒ
- Mount Specs: Β Β
- 90 mm diameter pins Β Β Β
- 485 mm center-to-center (pin boss) Β Β Β
- 360 mm inside-to-inside pin boss spacing
π© Key Features:
- Designed for trenching, profiling, cutting rock and cement walls, tunneling, quarrying, demolition, dredging, and even underwater applications Β
- Especially effective where conventional excavation methods fail and percussion tools are ineffective Β
- Ideal for carrier weight of 20 to 34 tons (excavators in the 200β350 class) Β
- Quiet operation makes it suitable for sensitive areas such as: Β Β
- Residential zones Β Β Β
- Schools Β Β Β
- Hospitals Β Β Β
- Bridges and critical infrastructure
βοΈ Performance Specs:
- Oil Flow Range: 45β66 liters per minute Β
- Max Operating Pressure: 5800 PSI Β
- Cutting Speed: 2.2 β 3.5 meters per minute Β
- Cutting Width: 35 inches β perfect for deep, narrow trenching
π― Operator Benefits:
- Highly balanced and controllable, making it easier to handle Β
- Allows for efficient corner cutting and precision work Β
- Recommended for finishing operations with: Β Β
- High precision Β Β Β
- Minimal disturbance Β Β Β
- Superior aesthetic results
π° As New Cost:
$125,000.00 USD
(Approx. $170,000.00 CAD) β Great value for a low-hour demo unit!
π½οΈ See It in Action:
π Watch on YouTube: https://youtu.be/BHGg1d8aLYY?si=09FO62UqLZm5Ughy
π Location:
1921 Lakeview Rd, Cambridge Narrows, New Brunswick E4C 1N
π Contact Frank: Β Β 604-476-7777
