SLASHBUSTER SG360 Stump Grinder 16 TO 40 TON EXCAVATOR MOUNTED SG360 36-INCH WHEEL STUMP GRINDER
Price: $40000.00
SLASHBUSTER SG360 36-INCH WHEEL STUMP GRINDER
Excellent Condition - Ready to Work
* Original Paint and Decals
* New Cost: $65,000.00 + USD = $89,000.00 CDN plus Shipping - Customs and currently 8 months wait from Slashbuster
Details:
This unit is in excellent condition, having been used for a single large park project. It effectively ground 4 acres of stumps while meeting city requirements to leave stumps in the ground with 6 inches of mixed soil and grindings on top. The grinder’s front rake excelled at this task.
The steep hillside park required the stumps and roots to remain as barriers against slides, soil movement, and erosion. The grinder also produced sawdust-like grindings, ideal for mixing into the existing soil, fulfilling another city requirement.
Specifications:
* Pin Size: 90 mm with 14.5 inches between bosses, expandable to 17 inches between bosses, and can be bushed down to 80 mm pins
* Center-to-Center: 19.25 inches, compatible with the PT12 Helac PowerTilt (see other ad for this unit)
* Hydraulic Requirements: 40 to 60 GPM at 3000 PSI, suitable for use on excavator auxiliary circuits even on 150 Class excavators
* Safety and Efficiency:
o Patented guide cones to prevent cutting wheel stalls
o Double heel rack for below soil level grinding, digging, raking, and trenching
o Enclosed cutting teeth for enhanced protection
Condition and Pricing:
* Current Condition: Excellent with original carbide steel cutting teeth still at 90%
* Price: $40,000.00 CAD
* Additional Option: As new hydraulic flow combiner valve with foot control valve for $3,000.00 CAD
Additional Information:
* Flow Combiner Valve: Enables higher flow volumes for attachments such as grinders, brush cutters, crusher buckets, and hydraulic hammers. Ensures smooth and responsive machine operation by utilizing flow from both hydraulic pumps.
* Quick Shipping: We offer great shipping rates and fast delivery.
Contact:
* Frank: 604-476-7777
Learn More:
* Brochure: SG360 Stump Grinder Brochure
http://www.slashbuster.com/images/SG360_stumpgrinder_brochure.pdf
* Video: SG360 Stump Grinder in Action
Enhance the capabilities of your 16 to 40-ton excavator with the SLASHBUSTER SG360 Stump Grinder. This unit is designed for safe, efficient, and cost-effective stump removal, featuring long-life carbide teeth and versatile functionality.
Don’t miss this opportunity to acquire a high-performance stump grinder at a competitive price. Contact Frank today!
SLASHBUSTER Excavator Attachments for Land Management | |
Brush CuttersFrom land clearing equipment to right-of-way vegetation management: brush cutter models are available to suit your application and excavator size from 3 to 30 ton. | |
Stump GrindersGrind stumps with your backhoe or excavator. Guide cones help prevent stalls, making the stump grinder easier to use and ideally suited to equipment rental yards. | |
StirrersMix solid materials such as mulches or aggregates, or incorporate material into a slurry for remediation applications. Our excavator mounted stirrer can be modified to meet your needs. | |
