XCENTRIC XC50 130+YARD PER HR JAW CRUSHER 400 - 650 CLASS EXCAVATOR JAW CRUSHER BUCKET
Price: $100000.00
The World’s Most Advanced Excavator Jaw Crusher Bucket  - Replaces $400,000+ Mobile Crushers — A Game-Changer for On-Site Crushing
✅ Compact, Powerful, and Efficient:
✅ Superior to Traditional Mobile Crushers:
Eliminates the need for a separate loader
Works efficiently in tight or restricted job sites
Adjusts output sizing in just 2–3 minutes, not hours
No conveyor belts to rip or fail
Minimal downtime – designed for reliability, not repairs
✅ Cost-Saving Advantages:
½ the fuel consumption
½ the insurance cost
Easily maintained – no complex systems like those in mobile crusher units
✅ Strategic Investment:
Replaces multiple machines
Faster set-up and teardown
Ideal for demolition, quarrying, and remote sites
 This bucket is a no-brainer for any serious contractor looking to cut costs and boost efficiency.
 Performance Highlights:
✅ Crushing Output: Over 130 + Yards Per Hour
Capable of breaking:
Hard granite, basalt
Wet or dry demolition debris
Load output directly into:
LOAD DIRECT INTO 10 tandem  13 CUBIC YARD dump trucks per hour
✅ Output Size Adjustable:
 1/2" - 1½" minus to 5" product
Granulometry adjusted in under 5 minutes (just drive 2 pins to adjust jaws)
New Replacement Value: $250,000+ SHIPPING AND 6-7 WEEKS LEAD TIME
 Your Price: $150,000.00 CAD JUST REDUCED TO $100,000.00
⚠️ Compare: Smaller used XC29 (½ the size) from Shearforce retails for $145,000 CAD - see image #6
 Technical Specs:
Model: XC50
Year: 2020 - LOW HOUR UNIT DUE TO COVID NOT BEING USED - ORIGINAL JAWS OVER 80% - ORIGINAL  PAINT AND DECALS
Note: We have a New Dealer Take Volvo EC380  off 8 foot stick we were going to mount on a EC380LC Volvo for quicker - easier - cheaper moves available for both this unit and the Rocktec Terminator 75000 ft lb drop hammer
Machine requires only a 2 way Hydraulic thumb circuit and case drain line - move the jaw bucket between mutltiple machines on multiple sites as required.
Weight: 6,250 kg
Jaw Opening: 1100 mm x 500 mm
Crushing Volume: 1.5 m³ per bucket = 2 Cubic Yards per bucket
Stock #: XC50-0001
CURRENTLY SET UP FOR OUR VOLVO EC 480LC WITH AND OR THE VOLVO EC380 LC :
110mm FRONT PIN - 18.5 INCHES BETWEEN EARS
100mm REAR PIN 16.5 INCHES BETWEEN EARS
22.5 inches center to center pin spacing
 Engineering Advantages:
 Minimal Maintenance Required:
Grease only every 200 hours
▶️Factory Manual for Excentric Buckets:
▶️COMPARISON GRANULOMETRY ADJUSTMENT, Xcentric Crusher vs. another crusher bucket
 Watch It in Action:
▶️ Model-Specific Demo:
▶️ Learn More from the Manufacturer:
 Contact:
Frank Rayner
 Phone/Text/WhatsApp: 604-476-7777
 Why This Unit?
✅ Low-hour,  original-paint, now professionally reconditioned
PLEASE SEE MY OTHER LISTINGS FOR THE ROCKTEC TERMINATOR  TX750 450-750 CLASS EXCAVATOR 75,000 FT LB HYDRAULIC DROP HAMMER FOR CONCRETE WALLS - SLABS TO 4 FEET THICK - SHATTERING ROCKS AND BOULDERS 1 TO 10 CUBIC METERS TO THEN RUN THROUGH THIS JAW CRUSHER BUCKET
https://www.kijiji.ca/v-view-details.html?adId=1555092945
 Crusher Buckets – Overview
Crusher buckets are jaw-type crushing attachments mounted on excavators. A rotating hydraulic motor powers the movement of the jaw, which crushes materials against a fixed surface. These attachments process material on-site to reduce size (typically from ¾ inch up to 6 inches), making it easier to reuse or haul away.
✅ Advantages for Demolition and Quarry Work
On-Site Material Processing
Eliminates the need to haul material to a stationary crusher.
Reduces overall project footprint by consolidating operations at the work site.
Significant Cost Savings
Cuts transport and tipping fees by reducing waste volume.
Lowers fuel consumption associated with moving heavy material off-site.
Operational Efficiency
Crusher bucket mounts directly to the excavator—no need for additional equipment.
Materials can be loaded directly into trucks or stockpiles after crushing.
Adjustable output size in minutes allows for rapid adaptability to different tasks.
Ideal for Tight or Urban Sites
Compact solution for confined demolition zones where bringing in larger crushing plants is impractical.
Reduces noise and environmental footprint compared to traditional crushers.
Versatility in Material Types
Capable of crushing:
Reinforced concrete with rebar
Brick, asphalt, and demolition debris
Natural stone like granite and basalt in quarry settings
Reduces Waste & Supports Recycling Goals
Turns demolition waste into reusable aggregate for backfill, road base, or resale.
Supports green building and sustainability initiatives by reusing on-site materials.
Enhanced Site Safety
Reduces material handling and double handling risks - CRUSH RIGHT INTO TRUCKS OR TRAILERS @ AT 10 YARDS FOR EVERY 6 MINUTES .
Keeps crushing tasks within operator control from the excavator cab.
Increased Productivity
Capable of processing over 130 CUBIC  yards per hour (model XC 50).
Keeps pace with demolition operations without slowing down other work.
Faster ROI (Return on Investment)
Lowers dependency on subcontracted crushing services.
Enables smaller contractors to self-perform work previously outsourced.
